A successive approximation register analog-to-digital converter (SAR-ADC) digitizes an analog input in into a digital output out using a binary search algorithm (i.e. successive approximation algorithm).
This SAR-ADC model is composed of an analog front-end, a comparator, and a digital finite-state machine. The analog front-end samples the difference between the analog input in and the reference controlled by the digital codes sel_dac<5:0>. The comparator then determines the polarity of this difference and delivers the result comp_out to the digital finite-state machine. Based on this polarity, the digital finite-state machine sets the next value of the digital codes sel_dac<5:0> via the successive approximation algorithm and produces the final digital output out<5:0> when its sequence is over.
| Name | I/O | Type | Description |
| out[5:0] | output | bit | digital output |
| clk | input | xbit | sample-and-hold clock |
| in | input | xreal | analog input |
List of Children Cells
| ADC_SuccApproxADC_FSM : A finite-state machine for a successive approximation register ADC |
| ADC_SuccApproxADC_Frontend : An analog front-end for a successive approximation register ADC |
| tb_check_sineinput : A testbench for checking the basic operation of an ADC with a sinusoidal input |
This testbench checks the basic operation of an ADC, by applying a sinusoidal signal to the input in of the ADC and observing its digital outputs out<5:0>. The testbench drives the input clk with a periodic clock.
The ADC is expected to produce a digital output corresponding to the same-frequency sinusoid.
Figure. input and output of an ADC.
