BLK_ToggleFF : A toggle flip-flop (T-FF)
A toggle flip-flop (T-FF) inverts its current output out whenever the input clock in rises.
This T-FF model is described with two gate primitives, dff_xbit and inv_xbit primitives. The parameter delay_cq sets the input-to-output delay (i.e. the clk-to-q delay) of the T-FF and the parameter init_value sets the initial value of the T-FF's output.
data='/asset/modelbox/BLK_ToggleFF/schematic.svg' type='image/svg+xml' class='modelbox-svg'
Name I/O Type Description
out output xbit output
in input xbit input
Name Type Default Description
delay_cq real 50p clk-to-q delay
init_value bit 0 initial output value
tb_check : A testbench for checking the basic operation of a toggle flip-flop
This testbench checks the basic fucntionality of a toggle flip-flop (T-FF) by feeding a periodic clock input and observing the output. The T-FF is expected to produce a periodic clock output with half the input frequency, which transitions at each rising edge of the input clock.
data='/asset/modelbox/BLK_ToggleFF/tb_check.svg' type='image/svg+xml' class='modelbox-svg'
Figure. the basic operation of a toggle flip-flop.
