TDC_IdealTDC : An ideal time-to-digital converter (TDC)
A time-to-digital converter (TDC) measures the timing difference between two input signals clk_fb and clk_ref and produces the output out<3:0> expressing the result in a digital format.
This ideal TDC model describes the ideal functionality of a TDC, using a clk_to_delay primitive followed by an adc primitive. That is, the clk_to_delay primitive measures the delay between the two input clocks clk_fb and clk_ref and the adc primitive digitizes the delay into a digital output. The parameters delay_min and delay_lsb define the range and resolution of the delay being digitized. The output is expressed in a two's complement format by adding an offset of -8 (4'b1000) to the adc primitive's raw output.
data='/asset/modelbox/TDC_IdealTDC/schematic.svg' type='image/svg+xml' class='modelbox-svg'
Name I/O Type Description
out[3:0] output bit output
clk_fb input xbit feedback clock
clk_ref input xbit reference clock
Name Type Default Description
out_min int -8 minimum output range
delay_lsb real 64p delay resolution
delay_min real delay_lsb*out_min minimum delay range
tb_meas_tfdc : A testbench for measuring the timing error vs. output transfer characteristics of a time-to-digital converter (TDC)
This testbench measures the timing error vs. output transfer characteristics of a time-to-digital converter (TDC) by gradually changing the timing difference applied to the TDC's two inputs. A probe_dc primitive sweeps the timing error and measures the TDC's digital output assuming it is in two's complement representation. The result shows the digital output code produced for each interval of the input timing difference.
data='/asset/modelbox/TDC_IdealTDC/tb_meas_tfdc.svg' type='image/svg+xml' class='modelbox-svg'
Figure. timing error vs. output transfer characteristics.
